Use 96VDC battery t...
Use 96VDC battery to directly power the DC input of the EG4 hybrid mini split A/C
(@phong-vo)
I am building an RV electrical system and using a EG4 Hybrid mini split A/C 12kbtu, my RV has a 96VDC 280A battery bank, can I use it to power the DC input of the A/C directly? I don't want to use an inverter because it is quite noisy. Thanks
Unfortunately, that isn’t possible, as the Mini Split is designed to operate only on solar or AC power. To use the batteries, you will need to use the inverter.
