Volt setting sectio...
Volt setting section Eg4 6000xp
(@stanley118)
I need help with my eg4 6000xp programming. I was told I needed to set the inverter to volts to charge my new batteries. I want to use the inverter to charge the batteries to start, no solar or generator. The manual has settings 1-30. Which numbers should I be working with to get to volts. Just very confusing to me at this point. Thanks
Here is a link to the manual. The settings start on page 46.
EG4-6000XP-Manual.pdf
  • Setting #3: Lead Acid (This is to charge by voltage)
  • Setting #14: Set Time for AC Charge (Set the time or voltage you want the inverter to use Grid to start and stop charging the batteries)
