Web Monitor acting ...
Question Web Monitor acting strange
Yesterday my gen ran, today it did not (all as expected).  However, if you look at the graphs you can see that for today the upper graph shows the gen did not run but, the lower graph says it did.
Any ideas?
This is certainly interesting! I will discuss this with the team to investigate further. It may not have successfully received the correct information, as the data appears to be identical to the previous day.
Thank you.
Make sure the time zones on your user and station under the Configuration tab are the same. If not, this can cause issues with the data being received. If you need help with this let me know!
They are both GMT-7, and never any problems before excepting at DST change.
