Menu
All
General
Announcements
Support
Educational
Forums
Recent Posts
Members
Forums
Announcements
Firmware Updates
Inverters
6000XP
EG4_ccaa-190E0F
[Closed]
EG4_ccaa-190E0F
6000XP
Last Post
by
1 year ago
1
Posts
1
Users
0
Reactions
913
Views
RSS
Based on ccaa-190D0E.
1. Added generator dry contact status ON/OFF on monitoring
2. Improved battery and BUS over voltage issues
3. Improved where the smart load power was not accounted for when connected to the grid
4. Improved where the smart load output had a long disconnection time when switching from on-grid to off-grid
5. Improved where the power flow display being abnormal in each phase under bypass status
6. Improved where could not switch to bypass when the PV off-grid status was abnormal in the parallel system
7. Improved where certain parameters would be reset to factory defaults when changing safety regulations or battery types
8. Improved where power generation not being saved or cleared
9. Improved where the dry contact did not work after GenBoost was enabled
Posted : March 10, 2025 4:07 pm
