12000XP and UL9540
Question 12000XP and UL9540
(@solar_pergola)
Will the 12000XP ever get UL9540 for ESS RSD when paired with approved batteries?
It seems it's only UL9540A.
Honorable Member
As far as I’m aware, this is not something currently in development. So, at this time, I would have to say no.
(@solar_pergola)
Posted by: @eg4eric
If the 12000XP is wired as pictured do you have to comply with UL9540? Or does it not need to because it isn't actually grid tied and there is no actual point of interconnection?
12000xp
Honorable Member
You would need to check your local code and utility requirement.
(@solar_pergola)
Posted by: @eg4eric
NEC 2023 requires ESS RSD. Even off grid NEC still applies? I'm surprised there is no plan to do this for the 12000xp.
Honorable Member
@solar_pergola
It depends, NEC 2023 does require RSD for ESS under certain conditions, primarily for firefighter safety. However, enforcement depends on local AHJ.
(@solar_pergola)
Posted by: @eg4eric
It looks like EG4 has decided to do it for the 12000xp according to the SS talk with Eric...are you the same Eric from yesterday?
