EG4 14.3kWh indoor ...
Breaking EG4 14.3kWh indoor wall mount battery BMS comms issues - resulting in blackouts, power blips, and charging restarts
12 Users
9 Reactions
12.7 K Views
(@krzysiek_kta)
@clarktheshark
My system is set to charge batteries to full both from PV array during the day and from grid overnight  and batteries get charged to 100% regularly, yet looking at the inconsistent voltage/SoC data when run in lithium mode I suspect the BMS is getting "off" after few months and start throwing some momentary error inputs to inverter (like low voltage, no battery, etc.) which causes the subject issues. The data is logged only every 4 min. so it is very difficult to capture those very instances and in most cases we can only see the inverter recovery from BMS hiccups.
From my experience after running for months in Lithium type 1 mode the subject problems start occurring (after 4 months in 20056  and 6 months in 2026). In both cases I switched to Lead Acid mode for couple of days , updated the firmware and power cycled the system as remedy
This year when the issues reoccurred the deep power cycling of the system alone did not help. Only after switching to Lead Acid for couple days  the firmware update and system power cycle solved the issue.
I am guessing, but maybe the top balancing the cells (read: couple cycles of charging batteries to full using voltage setting) is the fix?
Have you tried to top balance the cells in your batteries (set up the system in Lead acid mode and set the charging voltage to 56.4-57.0v and charge the batteries to full - in some sunny day or from the grid)?
Again, It is only my guess, yet putting the dots together make me think that the firmware update is not the primary fix, as in both cases the system worked flawlessly for months in Lithium mode running previous versions of firmware.
Just my 5 cents to share.
Brgds
K
(@clarktheshark)
I have always charged using SOC.
I have mine set to charge from 20-75% using grid power, regardless of the time of day.
I would say it's a weekly occurrence that the batteries reach 100%.
From everything I can tell, the cell voltages are all very close together even when the batteries haven't reached 100% SOC in a week or two.
I don't think it's a low voltage issue also because the problem usually occurs during peak PV charging.
Based on the logs, I'm seeing the battery comms just stop and restart.
- The inverter should not just freak out immediately in that scenario and cutover to grid. It should absolutely wait 10 seconds. During that 10 seconds l, it could fallback to Lead Acid mode maybe....
(@krzysiek_kta)
@clarktheshark
Before I got the battery firmware update cables (RS232 and RS 485 ) from RG4 last year I have been running my system in Lead Acid mode for over 4 months - no problems whatsoever. The only missing part was the SoC info of my battery - so  I was aiming to get back to Lithium mode as it supposed to work in the first place.
If the subject issues reappears I am going back to Lead acid mode for good - especially the latest 6000xp firmware has proper LIFEPO4 charge/float voltage management.
Let's see.
Brgds
K
(@clarktheshark)
@krzysiek_kta -
I wish we had better logging.. something is causing a fault and its not showing up anywhere from what I can tell.
- Another mild annoyance.. There is no consolidated place I can find where eg4 has its firmware versions along with its changelogs for its various products. It's all scattered amongst the forums and websites. Sometimes you have to download the zip files to get a changelog. Very frustrating when I'm trying to determine if a particular firmware update addresses the issues I'm having.
(@krzysiek_kta)
An Update.
After latest RS232 and RS485 BMS firmware update neither of my previous temporary solutions to make my system work in Closed Loop mode works for more than few hours.
regardless of my multiple attempts the issue of BMS randomly loosing comms with inverter persists.
Ultimately I gave up and set up the system again to run in Open loop mode (lead acid battery type) and it works flawlessly (I miss SoC a bit though).
Unless new firmware is issued for the battery BMS I am not going back to try Closed loop comms mode (Lithium 1 battery type)
Brgds
K
(@clarktheshark)
@krzysiek_kta - Yea, im not going to update mine until they specifically address the comms issue in the release notes of the firmware. I have comms drop out maybe once a week at this point.
(@nothing2crazy)
I’m still sorting through this thread, but this just happened to our household last night. The system had been running since May 3rd without incident. System consists of GridBoss, Flexboss, and two 314ah wall mount batteries. Last night, running on battery during peak hours, a parallel communication issue was logged in the event history followed by an RSD shutdown and our household was plunged into darkness just before 9PM.  I was left fumbling around in the garage with a flashlight to restart the system.
We have short cable runs between the equipment and batteries and I could find no loose connections or other problems this morning.
Page 4 / 4
