EG4 should offer a ...
EG4 should offer a busbar with Degson connectors
(@diglloyd)
EG4 supplies cables for its 18kPV inverters with a Degson connector on one end.  These cables are quite short, making it difficult or impossible to reach other than the first battery.
EG4 PowerPro batteries with Degson connectors (a Chinese knockoff of Amphenol SurLok) come with 42 inch cables, adequate for most purposes.
EG4 wiring recommendations are inherently unbalanced and thus stress battery #1 unduly.
My suggestion to EG4 is to offer an 8-port busbar utilizing the same Degson connectors as the PowerPro batteries.
With such a busbar, it would be elegant and easy to create a perfectly balanced plug-n-play system.
The balanced-wiring alternative of "diagonal wiring" is not attractive since one would have to make one's own custom cables.  And with excessive current flow, double-cabling is needed as well as 2X longer cabling in practical terms.
Thank you for your suggestions! We appreciate your detailed feedback and insights. I will submit this suggestion to our team for consideration.
If you have any additional thoughts or recommendations, please feel free to share them.
(@lemoeller)
@eg4eric did this ever happen/is it gonna happen? planning out using a busbar for my chargverter soon and would prefer to make it an easy plug and play situation with my current degson eg4 cables.
@lemoeller
We don't have any plans for this. However, our newest WallMount battery has a connection that you can connect directly to it instead of using external bus bars.
New Eg4 16kwh Indoor Wall Mount Battery - 48V 314Ah - YouTube
