Feature Request: Di...
Suggestion Feature Request: Display RS232 & RS485 Firmware Versions on Battery LCD's
(@lance)
I have been labeling my batts with the installed FW version(s), but it would be nice to easily VERIFY the actual installed FW version on each battery.
brent.wehry reacted
You can use the BMS Test software to view which firmware versions your batteries are currently running.
(@lance)
Posted by: @eg4eric
I realize that, but what’s the point of the LCD screen? I assume you meant BMS Tools, which is a bit more cumbersome.
You are correct.
BMS Test- Lifepower4
BMS Tools- LL-V2, Lifepower4 -V2, LL-S and WallMount batteries.
