Flex Boss-Should I ...
Flex Boss-Should I Use 1 or 2
 BobC
(@bobc)
I have 1 Flex Boss and 1 Grid Boss for a house yet to be built. I have 40- 450W BF panels that can produce 18,000 - 21,600 W on a perfect day. Since one Flex Boss supplies a maximum of 90 Amps to the Grid Boss, would it be better to split the array in half and have 2 Flex Boss's supply th single Grid Boss? This should allow more amperage to be supplied to the Grid Boss. This system will also incorporate 3- EG4 Indoor Batteries. Thanks in advance for your input.
One Flexboss should be sufficient, but it ultimately depends on your required output. Having two will provide more power, and you’ll have the flexibility to add more solar capacity in the future if needed.
BobC reacted
