Portable Generators...
Question Portable Generators (?)
11 Users
3 Reactions
(@mtmatt5150)
I am installing a grid tied solar setup with a GridBoss, FlexBoss 21, 18 panels, and 14KW battery.  My question is around using a portable gas powered generator with this setup.  I had previously used a Reliance Controls Pro/Tran 2 30Amp transfer switch to drive critical circuits in my house when the power went out.  This worked well with a little 4500W gas generator.
Can I  use a similar setup hooked into the GridBoss?  I suspect that this will work, in zombie apocalypse scenario where the a) the grid is down, b) the panels are covered in snow, c) the battery has been drained.  The goal would be to only use the generator to recharge the battery, or to just run a few circuits.
Anyone done this or have ideas?
-Matt
(@coolcat)
Hello Matt - I'm no expert but I'm looking to do something similar so I thought I would share what I've learned.
I too have a portable generator that we have been using to power our home during grid outages for the past 10 years. In my case it is wired with an inlet in my garage which is wired to an interlocked backfeed breaker in my main panel. I too want to retain the generator for use during extended outages that coincide with diminished solar production so I can use it to charge the battery back up.
What I found is that with small portable generators the best idea is to use a Chargeverter. I purchased one along with my batteries and other equipment. The Chargeverter converts the "dirty" power from the generator into pure DC power to charge the batteries directly, saving the inverter from having to deal with the generator connection. I hope this helps!
- Matt M.
Ron reacted
For optimal performance, it is recommended that the generator has less than 12% Total Harmonic Distortion (THD), is rated at least 1.5 times the total output of all inverters and provides a 240V output.
You can try to use a smaller generator with low amperage, but it is not guaranteed for it to work as it should.
(@Anonymous 1378)
(@Anonymous 1378)
(@decker)
I have a portable generator (20 amp; split phase) that was being used to power our home during grid outages for the past 8 years. It connected through a Reliant 6 circuit transfer switch. Last month I put in a 6000xp with 8 panels; changed the transfer switch to a 12 circuit 30 amp transfer switch (Nature's Gen). The solar array dropped my electric bill to $35/month and it gives me the power to switch any of the 12 circuits back to grid if needed. Then I installed an outside 20A receptacle to the generator input on the 6000XP. It works perfectly when I tested it. The XP sent generator power to the house and it also charged the batteries (Ruixu 48v).
I use a small 2000W 120VAC portable generator for exactly the scenario you have in mind - I use it to charge the battery bank and nothing else. In my case it runs through a Chargeverter and is connected to the battery bus. I limit the charging current to match the generator's capability using the settings in the Chargeverter. If you are going to try to use the generator input of the inverter or Gridboss, then as EG4 stated above you need to worry about sizing the generator to handle the loads that might be pulled through the system. I didn't want to invest in a larger generator just to handle this backup charging scenario, so the Chargeverter was a better investment to let me keep using my existing generator for the rare times it might be needed.
Ron reacted
(@lyrawinslow)
@jlankford That actually makes a lot of sense. Quick question though—when you limit the charging current, does it end up taking a lot longer to charge the batteries? Just curious how your generator handles running for that long.
@lyrawinslow
Yes, of course. It's a small generator so it can't charge as fast. I limit it to 1600 watts in the Chargeverter settings - 80% of the gen rated output. Not sure about your concern of it running a long time. If I didn't have my EG4 system, then that generator would be running continuously during a power outage just to keep the fridge and a few lights running.
(@lyrawinslow)
@jlankford
Yeah, I totally get where you're coming from. Small generators can only do so much, and limiting it to 1600 watts about 80% is a smart call — helps prevent overload and keeps things running smoother.
If you're in the same boat, where your generator’s working overtime just to keep a fridge and a few lights going, I’ve been there too. What really helped me was switching to a hybrid inverter setup — it took a lot of pressure off the generator.
Right now, I’m using this one:
Rich Solar NOVA 12K Hybrid Inverter – 48V 120/240V Split-Phase
If you’re facing a similar situation, seriously, check it out. It’s made a huge difference in how my system runs way more efficient and way less generator time.
(@smity77)
Would you not just feed the generator into the GridBOSS, and have the FlexBOSS 'clean' the power?
(@epenzenstadler)
@eg4eric
Please give a deep dive into this requirement. I have a system with 2 flexbos 21 inverters. That equates to a huge generator. NOTHING  in my house would require that size of generator. The worst load I have is a deep well pump.
Let's discuss the driving requirements for sizing the generator. And please explain in detail the settings and tradeoffs.
My system will also include ac connected solar of 10kw. How will the gridboss manage that during an outage to supply power and charge the batteries.
 crws
(@crws)
@eg4eric Would it be feasible to A/C couple an unbonded 120v 2000-4000w inverter generator with clean THD through a GridBoss Smartport instead of using an Autotransformer or Chargeverter?
@crws
No that would not be possible. That would not be a configuration that is supported by our system.
crws reacted
(@docjim)
Hello everyone!
I too am looking for a small generator solution. I am using two solar generators as uninterruptible power supply to a bank of freezers and my main refrigerator. I have three eg4 batteries that are used during power outage situations to maintain current to these two solar generators. The entire system will maintain the freezers and the refrigerator under normal conditions for about 4 days. What I'm looking to do is hook up my Chargeverter to a small propane generator to bring them up to charge. The charge burner Works excellent with the three rack batteries and I get accurate SOC readings.
What I would like to do is use the connection for auto starting the generator. I have looked everywhere and without a lot of personal investigation there does not seem to be any place that tells you what exactly needs hooked up on the generator to get it started. The manual says that it closes those circuits when the generator needs to start but I'm wondering if it stays closed even after the generator has started?
Outside of doing a bunch of Investigation has anybody hooked up the auto start feature on their generator and if so how did you do it?
