system display pann...
system display pannel
11 Reactions
That’s mostly correct. However, you might find this link to our API documentation for monitoring helpful: https://eg4electronics.com/api-documentation/.
Additionally, it’s worth noting that the RS485 port and the Wi-Fi module share the same interface. As a result, using third-party apps through the RS485 port may lead to some loss of functionality.
(@george-redinger)
Thanks Jared,
This is useful
From what I can tell, this api supports http get and post requests to  https://api.eg4electronics.com/api
And the requests are authenticated (presumably with the same auth  credentials that the EG4 cloud monitoring  uses.
The server that hosts https://api.eg4electronics.com/api
The EG4 server uses port 8000 through the reverse tunnel to get the inverters data via Modbus TCP commands.
The original topic "system display pannel" asks how to do a local connection to an EG4 inverter.
For a local connection, it appears that using Modbus TCP  to get/set  data is a requirement.
This is only my  "from what I can tell" interpretation.
For a minute I was excited  that I would be able to make requests to my EG4 18kpv via wifi  (http get and post requests).
George.
BobAndRoslyn
(@bobandroslyn)
@george-redinger  Regarding Chinese access to EG4 data, I do think we need clarity from EG4.
This topic probably deserves it's own thread.
Cc @jared
