HYbrid MIni Split C...
HYbrid MIni Split Condensate Pump
 MJT
(@mjt)
Good day. We are new to the forum and have been advised to check here for information, as we are working to install 4 x 24k Hybrid Mini splits, 24 REC panels and hardwired in a block building that requires the use of condensate pumps. These are not powered up yet, and have been looking to get information with little avail, regarding the signal cord "1,2,3"/power source to run a pump and an alarm source, if available, to shut down the unit if pump fails. Would anyone here have any experience on this topic?
Thanks in advance!
This is actually the first time I’ve heard of using a signal cord in this type of setup. I’m not sure if it would work or how it would work.
 MJT
(@mjt)
Hello, EG4. Is there any condensate pumps installation information available to help us with this install? We are uncertain by the available schematics what the voltages are @the evaporator, or what the P+/P- designation per. Is it DC voltage that runs the indoor fan, and what that voltage is? Is there a such thing as a DC condensate pump if so? We use them in conventional installations regularly when its desinated line 1 and 2 when its a 230/240 unit.
Thanks again in advance.
