6000XP Power to RSD
6000XP Power to RSD
(@bhbaker220)
Wondering what other controls on the 6000XP will shut off the 12 volt power to a Tigo Rapid Shut Down device other than the Emergency Stop Switch.  For instance, if you turn off the EPS switch do you lose the 12 volt power? How about the Power switch?  Battery breaker? Grid breaker? PV Isolation Switch?
12VDC will only be provided to the RSD power contacts when the inverter is powered on with the EPS switch set to the "On" position.
(@bhbaker220)
@jared I turned off the EPS switch on my 6000XP and the unit kept producing solar.  So I opened the bottom panel and sure enough, I was getting 12 volts of power to the Tigo RSD device.  After experimenting, it appears that the power switch on the right side of the inverter that controls the 12 volts to the Tigo RSD device.
Good to know, I wasn't aware of the EPS side of it.
