Deep Dive into Logs...
Question [Solved] Deep Dive into Logs on 6000xp
So, I have been reviewing the log files for the 6000xp.  Thinking about building a Grafana site but I want to understand the log files a bit better before diving too far in.
For my first look at the logs, I am looking at the EPS registers and I am wonder about some of the different items.
here is a snip of the logs
EPS Logs
I understand the diff between L1 and L2 - each leg of the 240.
I also get the Volts on each line
The ones I am wondering about is the different pEps columns(CP & CQ), sEps columns (CR & CS), and eEps columns (CT through CW) (pretty much hoping for an understanding of the e, p, and s prefixes).
and how these relate to the peps and seps columns (Y&Z)
Here’s a definition summary for each term:
  • epsVoltL1N – EPS Voltage of L1N: The emergency power supply (EPS) voltage measured between Line 1 (L1) and Neutral (N).
  • epsVoltL2N – EPS Voltage of L2N: The EPS voltage measured between Line 2 (L2) and Neutral (N).
  • pEpsL1N – EPS Power of L1N: The active power output from the EPS on Line 1 (L1) to Neutral (N).
  • pEpsL2N – EPS Power of L2N: The active power output from the EPS on Line 2 (L2) to Neutral (N).
  • sEpsL1N – EPS Apparent Power of L1N: The apparent power (active and reactive combined) from the EPS on Line 1 (L1) to Neutral (N).
  • sEpsL2N – EPS Apparent Power of L2N: The apparent power from the EPS on Line 2 (L2) to Neutral (N).
  • eEpsL1NDay – EPS Day Energy of L1N: The total energy output from the EPS on Line 1 (L1) to Neutral (N) for a single day.
  • eEpsL2NDay – EPS Day Energy of L2N: The total energy output from the EPS on Line 2 (L2) to Neutral (N) for a single day.
  • eEpsL1NAll – EPS Total Energy of L1N: The cumulative energy output from the EPS on Line 1 (L1) to Neutral (N) over its operational life.
  • eEpsL2NAll – EPS Total Energy of L2N: The cumulative energy output from the EPS on Line 2 (L2) to Neutral (N) over its operational life.
  • pEps – EPS Power: The total active power output from the EPS across all lines.
  • sEps – EPS Apparent Power: The total apparent power output from the EPS across all lines (active and reactive power combined).
@jared Perfect thank you very much.
