Inverter shared bat...
Question Inverter shared batteries
(@tallbill)
I talked to an EG4 engineer on the phone about 9 months ago for my system design.  I was going to use three Flexboss21s, six indoor 280Ah batteries, 30KW of solar and the generator input.  I was not going to use Gridboss at the time. The engineer said everything was fine, but I should not use shared batteries because of a feature I needed.  He recommended dedicating two batteries to each Flexboss.  He gave me the reason, but I do not remember what it was.  My system just got installed with a Gridboss.  The installer configured the system with the six batteries shared across all three inverters. What is the feature difference between shared and dedicated batteries? What do you recomend?
@tallbill
The best configuration is to share the batteries across all three inverters. The Share Battery option was designed for customers who lack sufficient space to install the system as a single unit.
When the batteries are shared across all three inverters, the system draws from the entire battery bank.
