Unable to connect t...
Unable to connect to 18kPV dongle
@samjam24x7
The dongle does not need to be activated with a code. You only need to do the following
  • Connect your phone to the dongle’s Wi-Fi network.
  • Open the app and select Dongle Connect.
  • Enter your home Wi-Fi credentials.
  • Select HomeWiFi Connect.
  • The dongle will connect to your Wi-Fi network and the server.
  • Once connected, all three lights should be solid (steady).
If this doesn't work for you, please let me know and I can send you a replacement dongle.
(@samjam24x7)
@eg4eric
First two steps work and I am not able to get to :
@samjam24x7
Can you share a screenshot of what you're seeing?
I would like to confirm it's not the app. If it's an issue with the app, sending another dongle won't fix the issue?
