[Closed] Previous Changes
V3.39
3/19/2024
  • Further optimization of MOS fault detection logic under specific current conditions.
V3.38
3/8/2024
  • Optimize judgment condition for MOS fault detection.
  • Modify MOS fault detection to use current values during disconnection.
V3.37
11/23/2023
  • Remove PCS communication policy for host battery identification.
  • Change hardware current limiting mode.
  • Improve multiple battery parallel charging process.
V3.36
11/8/2023
  • Further optimize charging and discharging strategies.
  • Enhance short circuit and overcurrent fault handling.
  • Add parallel battery data code for host broadcast.
  • Introduce hardware current limiting policy adjustment.
V3.35
10/15/2023
  • Optimize MOS fault bugs triggered by battery over-current protection.
  • Add circulation discharge overcurrent and charging short circuit fault reporting.
  • Enhance handling for parallel batteries with high-voltage packs.
V3.34
10/13/2023
  • Add MOS fault alarm code and prohibit automatic restart for maintenance.
  • Add buzzer alarm function for maintenance failures.
  • Optimize charging and discharging strategies, including short-circuit precharging.
V3.33
10/10/2023
  • Optimize handling strategy for charging short circuit faults.
  • Add new charging short-circuit fault signal reporting.
V3.32
9/9/2023
  • Update charging and discharging current reporting.
  • Adjust monthly PCS agreement adaptation.
  • Support upper computer configuration for current limiting.
V3.31
8/7/2023
  • Request the total charging voltage to be changed to 57.6V.
V3.30
8/4/2023
  • Change discharge over-current locking to 1 time to prevent battery issues.
  • Adjust alarm and protection thresholds.
  • Add new charging and downflow software strategy for parallel batteries.
  • Optimize Schneider inverter charging strategy and update SOC calibration parameters.
V3.26
7/14/2023
  • Optimize the charging and discharging strategy of the inverter for battery packs.
  • Change charging voltage from 56.4V to 58.4V.
  • Enhance charging prohibition strategy and SOC calibration strategy.
V3.24
6/25/2023
  • Add support for the new version of the Maghren protocol, supporting the policy of prohibiting charging and releasing, and compatibility with previous versions.
  • Optimize SOC fill and vent strategy and support SOC calibration under specific conditions.
  • Optimize SOH calculation for wear rate, supporting SOH attenuation to 80% after more than 5000 cycles.
V3.21
2/13/2023
  • The charging voltage of the inverter has been modified from 58V to 56.4V.
V3.20
12/22/2022
  • The zero-drift uncalibrated current has been modified from 2A to 3A.
  • Add the Paineng 485 inverter protocol.
  • Add the 485 protocol for the Sun Moon Yuan inverter.
  • Add the LuxPower inverter 485 protocol.
  • Add EG4 LL V2 battery master-slave communication protocol and change the Baud of internal networking from 9600 bps to 19200 bps.
  • Set strong charging flag for individual voltage under-voltage or total voltage under-voltage protection.
  • Add an inverter protocol interface for upper computer selection.
V3.17
9/3/2022
  • Add charging short circuit interrupt filtering function, and only report over-current protection after 10 consecutive interrupts.
  • Increase the number of charging short-circuit interruptions and MOS status in historical records.
  • Modify the Schneider inverter communication protocol to master-slave mode.
V3.15
8/5/2022
  • Shield heating function.
  • Add tooling Short-circuit test function.
V3.14
8/3/2022
  • Change the short-circuit and precharging logic to enhance the precharging capability.
  • Add Blue Sun inverter protocol.
  • Add Schneider inverter protocol.
V3.10
3/2/2022
  • Add the communication protocol for the SMK inverter of the SMANCO.
V3.7
1/7/2022
  • Modify the charging over-current protection locking logic.
  • Optimize the main MOS temperature and current limiting MOS temperature reporting logic.
  • Optimize the charging and discharging MOS closing time to quickly close when the current is greater than 5A.
V3.6
11/5/2021
  • Change the precharging small board control timing.
  • Change the short circuit protection release delay to 5 seconds.
  • Change the SOC forced calibration to 0 under voltage protection.
V3.5
9/18/2021
  • Change the current capacity processing error of the SOC module.
V3.4
9/8/2021
  • At the request of the customer, modify the display order of the SOC indicator lights to increase from left to right.
V3.3
8/18/2021
  • Modify the short circuit and precharge control logic to restore it to the first shipment status.
  • Modify the total pressure collection conditions.
V3.2
8/12/2021
  • Increase total pressure collection DEBUG control.
  • Add pre-charging relay DEBUG control.
V3.1
8/11/2021
  • First version firmware.
Posted : October 11, 2024 5:45 pm
Arne reacted
