NEW EG4 WallMount 3...
Breaking NEW EG4 WallMount 314Ah Indoor Battery
7 Users
3 Reactions
Introducing the all-new EG4 WallMount 314Ah Indoor Battery — a next-generation energy storage solution designed for homeowners and small businesses seeking reliable power and total control. This newly released 16.0 kWh wall-mounted battery delivers 200A of continuous output, offering powerful whole-home backup in a sleek, compact design built specifically for indoor installations.
Engineered with advanced safety protections, intelligent self-heating for cold environments, and an easy-to-use monitoring interface, the WallMount 314Ah sets a new standard for simplicity, safety, and performance. With a 10-year warranty and an impressive lifespan of 10,000+ cycles at 80% depth of discharge, this new release provides long-term, dependable energy storage you can count on.
Click here to learn more
Posted : November 19, 2025 8:26 pm
PowerUp reacted
 T345
(@t345)
Is it available for purchase yet?
Also I have  two 280ah indoor wallmount, can this be added using the parallel indoor cable?
Posted : November 19, 2025 8:31 pm
(@powerup)
Great news - Impressive evolution!
  • Could you please offer tech details about combing this unit with existing 280Ah Wallmount?
  • For instance this new unit has Active Balancing
  • How will the separate Wifi connectivity be leveraged
    • Just for Firmware upgrade? Or more data about battery performance (like cell level voltage to Monitoring server)?
Appreciate the accessibility of the BMS for long-term maintenance.
Posted : November 19, 2025 8:48 pm
@t345
currently only available in US
Yes, however, you will need to set the New 314Ah indoor battery as the master battery and this configuration is not a UL9540 configuration.
Posted : November 19, 2025 9:10 pm
T345 reacted
I'm gathering more details on paralleling these batteries together and also about the Wi-Fi Antenna.
It does have active balancing.
Posted : November 19, 2025 9:41 pm
PowerUp reacted
(@sunnyside)
is it likely that the 12000XP will get 9540 ESS certified with the new WallMount 314Ah battery?
(assuming the system has only the new 314Ah batteries and none of the old 280Ah batteries and no mixing).
Posted : November 22, 2025 12:28 am
@sunnyside I don't have any additional information on that, but as soon as I do, I will let you know!
Posted : November 24, 2025 10:28 pm
 der
(@der)
Please expand on the 12000XP with 314Ah UL 9540 certification. Is it currently undergoing evaluation?
Posted : November 26, 2025 1:57 pm
I will look into this, but at the moment I don't have any information on the 12000XP and the new WallMount battery being certified for UL 9540
Posted : December 8, 2025 10:54 pm
(@jep83)
@eg4eric is there any plan to get the combination of 314 and 280 batteries UL certified?
Posted : January 1, 2026 3:07 pm
@jep83
I haven't heard anything regarding this yet, but I will see if I can get any information on it.
Posted : January 2, 2026 10:34 pm
(@jep83)
@eg4eric thanks.  Have 3 of the smaller and bought the larger without realizing they weren't completely compatible.  Surprised by that
Posted : January 2, 2026 11:10 pm
(@powerup)
@eg4eric Can you please offer or direct to Technical information on how the Active Balancers are set?
Balance Start Voltage, Balance Current (doc says 2-3A ... what circumstances causes it to be each), Balance Trigger Delta, Balance Stop Voltage?
Will any of these be configurable by the installer?
Finally, If necessary can this be activated/deactivated?
Appreciate your attention, looking forward to EG4's continued success in 2026!
Posted : January 4, 2026 7:03 am
(@powerup)
@eg4eric announced some important improvements with new firmware for this battery.
How does someone upgrade that firmware wirelessly?
Posted : January 8, 2026 9:22 pm
Posted by: @powerup
I’m looking into this and have consulted with our battery technicians. I’m currently waiting for their response.
Posted : January 12, 2026 2:51 pm
