BMS 15 W charge lim...
BMS 15 W charge limit Bug
(@belandbroc)
so I spoke with tech support yesterday on my two batteries that have this issue.  they immediately changed my 12000xp to lead acid to get it working again (work around) and then sent me a text message with a video called "EG4 48v lifepower4 batteries how to update firmware".  Problem is in the video it shows EG4 mailing some dude a packet with a usb device to fix the problem.  My tech only sent me the video and then hung up, nohting is being mailed to me.  I have called back many times and just put on hold for ever and ever.  anyone have suggestions or should I just buy the RS485 cable and hook my laptop on it and try that fix?
@belandbroc
That sounds like an issue with the Lifepower4-V2.
Do you have a Lifepower4-V1 or Lifepower4-V2?
(@belandbroc)
Eg4 314ah batt
@belandbroc
If you have your inverter online, I can update the battery remotely through the inverter. If you don't have it online, you would need to purchase the RS485 cable, or we can send you one.
(@belandbroc)
I do have it online and the serial number is 60534a0109
