Lead Acid Help
Lead Acid Help
(@bryantom)
So I was recently given some Lead Acid batteries so I have them hooked up to my Hybrid 18KW, but I need help with the settings.  I would like to Charge the batteries first and then consume the produced solar power.  I would like to discharge the batteries at night when there is no solar.  Can someone help me with the settings in order to achieve this?
You can configure PV Charge Priority so the batteries charge first, and once they are full, the inverter will use solar power to supply the loads.
