Masonry drill bit t...
Question Masonry drill bit to use to pre-drill for the wallmount battery bracket into brick
(@sunnyside)
what drill bit size should be used to predrill for the expansion bolts for the wallmount battery bracket?
Could page 18 of the wallmount battery manual be updated to state which size masonry but to use to predrill for the bracket when mounting in brick/concrete? -
https://eg4electronics.com/wp-content/uploads/2025/10/EG4-WallMount-314Ah-Indoor-Battery-Quick-Start-Guide.pdf
I’m guessing a 3/8 bit is the closest. But it would be nice to have this in the manual.
@sunnyside
That is correct! You will use a 3/8 bit!
