18kPV settings myst...
Question 18kPV settings mysteriously change after "Start Quick Charge"?
BobAndRoslyn
(@bobandroslyn)
Repeatable scenario:  I have my 18kPV configured for AC Charging based on Voltage.  Prior to a storm we will often use the "Start Quick Charge".  After the charging session the AC Charge settings are sometimes unset, sometimes just not honored.  The result is the system moves to some sort of continuous charging mode.
I'll be opening a support ticket, but wondered if anyone else had see this.
This only happens when you use Start Quick Charge?
BobAndRoslyn
(@bobandroslyn)
BobAndRoslyn
(@bobandroslyn)
Also note, the issue is recurring.
Are you able to run quick charge again so we can monitor the system while the charging is happening, and we can look at the settings to see what exactly is going on? It doesn't have to be today.
Page 1 / 3
