Battery details mis...
Battery details missing after firmware update
5 Reactions
(@james)
Have two FlexBoss21's, four 280Ah All Weather Wallmounts, and a Gridboss. Just upgraded the batteries to S02T25 and Z02T28, now I only see this in the monitoring site. It does see the 4 batteries under devices. Battery setting is Lithium and Brand 1.
Have power cycled the BMS on each battery and also restarted the inverter, what else can I try?
Screenshot 2026 01 31 at 1.45.39 PM
Screenshot 2026 01 31 at 1.49.14 PM
(@james)
This is what I get in dev view, only thing I changed is replaced the serial number with 123456789
"success": true,
"serialNum": “123456789”,
"lost": false,
"hasRuntimeData": true,
"statusText": "normal",
"ppv": 0,
"pCharge": 0,
"pDisCharge": 0,
"batStatus": "StandBy",
"batPower": 0,
"soc": 28,
"vBat": 523,
"pinv": 0,
"prec": 0,
"peps": 0,
"maxBatteryCharge": 1120,
"currentBatteryCharge": 313.6,
"batteryArray": [
"batteryKey": “123456789_ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ",
"batterySn": "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ",
"batteryType": "BATT_default",
"batteryTypeText": "",
"lastUpdateTime": "2026-02-03 01:42:17",
"batIndex": 3,
"batBmsModelText": "Unknown",
"lost": false,
"totalVoltage": 5239,
"current": 0,
"soc": 30,
"soh": 100,
"currentRemainCapacity": 84,
"currentFullCapacity": 280,
"currentCapacityPercent": 30,
"batMaxCellTemp": 0,
"batMinCellTemp": 0,
"batMaxCellVoltage": 3276,
"batMinCellVoltage": 3273,
"batChargeMaxCur": 140,
"batChargeVoltRef": 560,
"batMaxCellNumTemp": 2,
"batMinCellNumTemp": 2,
"batMaxCellNumVolt": 2,
"batMinCellNumVolt": 7,
"cycleCnt": 19,
"fwVersionText": "2.28",
"chgCapacity": "",
"disChgCapacity": "",
"ambientTemp": "",
"mosTemp": "",
"noticeInfo": ""
"remainCapacity": 84,
"fullCapacity": 280,
"capacityPercent": 30,
"totalNumber": 1,
"currentText": "0",
"currentType": "unknown",
"totalVoltageText": "52.3"
(@powerup)
You seem to be experiencing the same 280AH firmware upgrade issue as has been reported.
https://forum.eg4electronics.com/community/tsb/field-impact-notice-48v-batteries/
We upgraded to Z02T11 (For the inside wall mounts).
(@cshurtz)
The same thing happened to me after just upgrading firmware on my 3 indoor 280ah batteries. Have you figured out anything yet? I can only read one battery also.
(@powerup)
@cshurtz the EG4 suggestion(s) was to revert to lead-acid mode (not an option for our client).
it is unclear if that helps to see the data for all batteries.
Other option is to reload older firmware. EG4 has not made this available on the download page.
Again, not an option for our remote client anyway.
In our view the right process would have been to limit the damage and remove the new firmware as soon as they confirmed the issue.
That would have avoiding affecting you, and many others that have continued to be caught by this problem over the weeks since confirmation.
i pointed this out, but they still have that problematic firmware as recommended download on their site.
We apologize for the delay. A new firmware has been released for both indoor and outdoor WallMount Batteries that resolves the display error on the EG4 Monitoring webpage. The firmware is available for download on the EG4 Forum and the EG4 website.
Thank you for your understanding and patience.
Batteries – EG4 Community Forum
(@cshurtz)
@eg4eric  Just updated my 4 280ah indoor batteries. I can now view all the batteries! Thanks!
@cshurtz
If you run into any other issues, please let me know!
(@powerup)
@eg4eric Thank you, this solved the client issue. We installed and have tested. Forum members should know that it can take 15+ minutes to register (in our case we needed to delete the old battery from the list - not sure if it would have removed itself on its own). This should be listed as closed now. A big relief!
