Fixing 1200XP Firmw...
[Solved] Fixing 1200XP Firmware Update on off-grid systems
(@twistedroutes)
I'm sure there are other ways to do this, but as my replies to other posts are still "awaiting moderation" I thought I'd start a new topic.
With an off-grid system, when I performed a firmware update via the website, vs the app, I found myself in standby mode with no EPS output...in -15C and waterlines freezing, I couldn't wait too long (thanks Ryan @ Canadian Off Grid for calling back so swiftly and always answering my text message).  Anyway, here's what I came up with to recover:
12000XP is in Standby state 🙁
  1. Turn off EPS, turn off inverter
  2. Turn on the generator. Optional that I do or my lines would freeze
  3. Turn on inverter and EPS
12000XP is in bypass state and atleast keeping my lines from freezing.
  1. Find an iOS device, install app
    1. @EG4 STILL have not updated the Android app to include firmware for 12000XP
    2. We had to borrow an iOS device as we are all Android
  2. Connect to Dongle WIFI (not home wifi) in my case DJ4XXXXXXX
  3. Open EG4 Monitor App (may need to restart it)
    1. you have no internet so it should be back at the main page
  4. Select "DOWNLOAD FIRMWARE"
  5. Change WIFI Network to something with Internet Access
  6. Return to app and select 12000XP
    1. This should list some files that will be downloaded
    2. If not, change to a different inverter in the dropdown list and then change again to 12000XP
  7. Select the 12000XP and click DOWNLOAD. Wait for download to complete
  8. Change WIFI Network back to Dongle WIFI (not home wifi) in my case DJ4XXXXXXX
  9. In the App select "CONNECT DEVICE AND UPDATE"
Here what happens now:
  1. Files are uploaded to inverter. App says "Successful" (misleading!!!)
  2. Inverter will disconnect power (EPS) and begin updating
    1. you can watch progress on the inverter LED (not in App)
  3. Inverter will restart after update is complete
After about 30 seconds EPS should be restored and you will be powering loads in non-bypass mode.
In my case, I then stopped the generator, switched back to "Auto". After about 30 seconds the inverter called the generator via 2-wire (COM2/NO2) and started charging the batteries as well as powering loads.
Were you able to get the firmware update installed?
If you have the inverter online, I can update the firmware for you.
(@twistedroutes)
Thanks Eric, Yes I got it done when I borrowed an iPad.  I am concerned about the next attempt to update though.  Can you please:
1. update the Android app to include files for 12000XP
2. examine why the firmware update fails via the web when no grid is available
Thank you!!
