I need my 24 hour A...
I need my 24 hour API restriction lifted
(@rmcelwee)
My system has been down for a while while moving to my new house and when I brought it back up I see I am blocked from making changes to it. I think it was due to Home Assistant polling too often. I have deleted the EG4 integration with Home Assistant so that problem should be solved. I need to make changes before my batteries run dead. Is there someone here on Saturday that can lift this for me before it is too late? Thanks! Here is a serial number if it helps - 5074850625 .
(@rmcelwee)
It has been 36 hours so you can probably delete this...
