W000 W026 W027 erro...
W000 W026 W027 errors on discharge low SOC - 18kPV
(@he-04)
I have a Gridboss/18kPV/29kWh whole house battery backup.  Twice now on meeting my cut-off discharge set point the system shut down with errors W000 (battery comm failed), W026 (battery under voltage), W027 (battery open circuit).  I had to reset batteries and inverter to get things going again.
The first time it happened during normal operations right at my on-grid cut-off SOC set point of 35%.  The second time it happened when I tried to bottom balance and SOC hit 0%.
Should that happen?  How can I bottom balance the battery without the system shutting down?  Do I need to or is top balancing occasionally enough anyways?
(@he-04)
Whoops.  Flexboss inverter, not 18 kPV if it makes a difference ...
What batteries do you have with your system?
Did the errors recently start, or have they been happening since you installed the system?
(@he-04)
I have 2 EG4 wallmount allweather batteries with it.  The system is only about 3 months old, so I'd say both ...
Are you still experiencing those warning codes every day?
If so, we recommend reaching out to your distributor for a replacement. This issue has been identified with certain Flexboss inverters.
If you haven't, we can continue troubleshooting to see what caused those codes to pop up.
