[Closed] EG4_ccaa-1C1212
EG4_ccaa-1C1212
2025-11-16
  • Based on ceaa-191011 or ceaa-1A1111.
  • 1. Add Quick charge function.
  • 2. Add Max AC input setting to reduce the charge power when the AC input over this value.
  • 3. Add time setting for generator charge.
  • 4. Add generator quick start and generator exercise function, remotely start generator for 20 mins.
  • 5. Add generator warm up and cool down logic, waiting for 2 minutes when starting and shutting down the generator.
  • 6. Add mode of lithium battery without communication (brand 30 31)
  • 7. Add smart load power display.
  • 8. Add buzzing prompt when triggering battery warning voltage.
  • 9. Optimize the fan noise.
  • 10. Optimize the fan logic by allowing fan3 to rotate together with fan1 and 2 to optimize the air duct.
  • 11. Optimize the possible BUS voltage high alarm that may occur during battery overcharging.
  • 12. Optimize relay switching stability.
  • 13. Fix the issue of abnormal load power consumption calculation after enabling the AC COUPLE function;
  • 14. Fix the issue of not clearing the W04 warning when setting from lithium battery to lead-acid battery type;
  • 15. Modify the lower limit of Absorb voltage and Float voltage for lead-acid mode from 50V to 48V
Posted : December 12, 2025 5:37 pm
peart504 and dtbaker61 reacted
