Feature Request: EG...
Feature Request: EG4 Monitor App LOCAL NETWORK Access
9 Users
7 Reactions
(@lance)
Though monitoring EG4 inverters/system can be done by attaching directly through the wifi dongle (or the cloud), the ability to view the system through a local network would be very helpful. For example, I can attach directly to my 18Kpv inverter through the wifi dongle, but my dongle is 100 yards away from my house. It is connected to my local wifi network, but I cannot access it through my local network, but only through the cloud or directly to the dongle.
For those who are off-grid, with no internet access, or would like to monitor their EG4 system when the internet is down, the ability to monitor the EG4 system through a local network would be very helpful.
potrero reacted
Thank you for your feedback. As you mentioned you can connect to the dongle locally by connecting to the dongle's network. However, I will share this feedback with our team.
(@lance)
@eg4eric, my solar shed is not within WiFi range of my home, but I have a well-distributed network around my property.
(@dougl)
Depending on your skill set there is an option which combines 2 open source projects. To get data from your EG4 inverter( 18kPV and 6000 supported ) there's Python Protocol Gateway( https://github.com/HotNoob/PythonProtocolGateway ) which I run on a Raspberry Pi and connect to the EG4 18kPV via RS485->USB cable.
It acquires data from the inverter and publishes it to a MQTT server( which can also be running on the Raspberry Pi. For display I use MQTT Explorer.
For a better looking display than a bunch of MQTT messages the next open source package is Home Assistant( https://www.home-assistant.io/ ) which can also run on the Raspberry Pi.
It can do far more than display solar inverter data for example I have a 3rd open source package in my solar system setup which is YAMBMS( https://github.com/Sleeper85/esphome-yambms ) which sits on an ESP32 between my batteries and the inverter and allows me more control of information and charge/discharge and many use it to read from a Smart Shunt for more accurate SOC information and provide that to the inverter instead of what the batteries think is their SOC. I have a CAN interface from the ESP32 to the EG4 18kPV inverter and another one to the DIY Basengreen batteries(3*16kWh).
Here's one of my 4 solar system display panels seen in a web browser.
Unfortunately, while Home Assistant sells a kit to get going, the YAMBMS doesn't but Python Protocol Gateway is, like Home Assistant pretty much a software only solution for inverter data collection and display. They are Linux solutions and as you mentioned, they are local LAN based so no Internet connection is required and no data is lost if there's a cloud issue or Internet disconnection.
dfwtinker
(@dfwtinker)
Hello @lance,
I too had a "long way from the wifi" situation.   I was able to resolve my problem using a wifi extender and a poe++ extender.  Between the two I now have 4 bar reception wifi approx 450 feet from the front door of my shed.
 For some reason the Amazon URL would not resolve so I put the pictures in so you could get the names and look them up if you need them.
 PoE Texas PoE++ Extender - Outdoor PoE Repeater - IP67 Waterproof and Direct Burial Capable - High-Speed Ethernet Booster Extends Power and Gigabit Data Range by 100m - IEEE 802.3bt/at/af Compliant
I have had very good performance from both and setup was a no-brainer.
Hope this helps.  Good Luck!
Lance reacted
(@marobel)
@dougl I, too, am looking at polling my 6000xp for battery, inverter and PV information.  Just recently I completed my own Telegraf, Influxdb and Grafana setup on a Pi 4, pulling data from the SA mqtt broker. I’m now working on getting data directly from the inverter to bypass (without prejudice!) Solar Assistant.  I didn’t want to get into HA. Didn’t want to have yet another app I needed to master.
Thanks for the GitHub link. I’ll look into this asap.
(@potrero)
I share this feature request. On a related note, it would be helpful if the dongle showed RSSI and if the dongle could be polled for RSSI prior to finalizing the placement of the enclosure (ex. by connecting to an HDMI cable connected to a USBC adapter to a laptop, which powers the dongle and can pull RSSI to ensure the proposed inverter location is a good one).  Same request applies for both wifi and cellular dongles.
(@mbbush)
If I get an ethernet dongle, can I connect to that locally in a similar way to the wifi dongle?
My systems aren’t on the net. I’d love a data recorder for the 18k that could be plugged into a laptop once a month and then download the info.
(@dougl)
@pawnee what I mentioned does not require being "on the net" which I have to assume you mean Internet. Those things can run both stand-alone or on a local LAN once setup.  When setting up they do require downloading and updating over the Internet but once running the Internet is not required.
But if you didn't catch that to begin with you might not have the skills to pull off the setup without lots of time learning new skills.
(@marobel)
@dougl I posted before that I’m capturing the SA mqtt broker output for my monitoring system. What did you use to get data directly from the inverter? Did you use an hdmi to RJ45 adapter or just pickup the Wi-Fi dongle output directly?
(@dougl)
Posted by: @marobel
I'm using Python Protocol Gateway on a Raspberry Pi with an USB-to-RS485 cable which came with one of my Basengreen battery packs. On my EG4 18kPV there is an RS485 port under the RJ45 connectors on wire terminals. That's the RS485 channel I'm using. I believe it's used for intercommunications between GridBoss and FlexBoss devices.
(@marobel)
Yes, I’ve seen that the the more advanced EG4 inverters. They have the terminals you can tie into.  The 6000xp does not have that same setup.  I was hoping to get the information by using the paralleling ports (whereby you can add multiple inverters). It seems like this should be exchanging the information I’m looking for.  I just need to get that worked out.
DougL reacted
(@carlrx7)
I just wanted to share a solution that gives me lan access to the dongle while still connected to my home wifi.  I'm running a glinet router that supports multi-wan.  I added the dongle wifi to the repeater mode.  I'm not sure of the details of why this works, but I'm able to use the local connect on my home network now.
Marobel reacted
(@marobel)
I’ve finally got all this working! I outdoor that the dongle had to be removed for me to get good data from the rj45 connection just above the Batt Comms plug. Found the inverter register mapping and used that to decide the data.  Now dumping 30 second readings into json and getting directly into my Grafana visualizations.
