I need help to update the battery firmware on my system, I have FlexBOSS21 and 3 EG4 WallMount indoor 314Ah batteries.
@rick13
I can update the batteries remotely for you or I can also walk you through the process of doing it if you prefer to update them yourself.
I would just need you to provide the inverter's serial number and make sure the dongle is connected to the internet.
@rick13
There is no need to turn anything off or change any settings. As long as the batteries are communicating properly with each other and the inverter, the system should operate normally, and the batteries should update without any issues.
I noticed the inverter is set to Lead Acid mode. Is there a reason for this?
We would need to change it to Lithium 1 to establish proper communication.
It looks like the update was completed successfully on all three batteries, and the charging limit is no longer being limited. Everything appears to be functioning properly at this time. If you experience any issues, please let me know!
