Daylight Savings Ti...
Daylight Savings Time
10 Users
11 Reactions
(@dtbaker61)
I have a related but different take on this. I have an offgrid install where I am more interested in setting system time up so that the reports consider my "day" to start at 7am as 00:00 in the data. My real time is -7 GMT (mountain standard time in US). Can I accomplish what I want by setting "system time" to 0 GMT, or would it be +7 GMT ?
and.... when would it show up in the monitoring/reports ?
or, do I leave the system set to -7GMT, and set the time in the clock setting ?
(@dtbaker61)
what I am finding so far is that the timezone GMT setting will override the clock setting, so the only way to approximate what I want to see for "daily totals" is to set system to -2 GMT, which should make my "midnite" occur 5 hours early, at 7 pm, which will be acceptable since it *should* show the full day's production and consumption in the same "day"... making it easy to see what my battery kWhr in/out is.
part of the reason I want to do this is specifically for off-grid sites to make it easier to get clients to think in terms of actual kWhr rather than unavailable and inaccurate SOC since I am configured open loop battery management by voltage setpoints rather than SOC%
(@rsudbay)
I am having the same issue. I have to toggle DST on and off, and change my GMT all around to try and get the time to line up. Any update on this fix?
@rsudbay
It has been brought to my attention that DST is not working. I have reported this issue and once it's resolved we will make an announcement.
(@powerup)
@eg4eric Its been 4+ weeks since we switched off DST.
Has Engineering implemented a solution but not rolled it out?
If the solution needs firmware updates then it would be a huge missed opportunity if this isn't solved in the next release.
I am explicitly asking if engineering has resolved this in-house yet. 😶
(@potrero)
Please prioritize this issue. The time needs to be correct for the time based controls to be useful / reliable.
This issue has been reported to Engineering; however, I have not received an update on their progress yet. I will follow up with them and provide any updates as soon as I have more information.
(@powerup)
We are now less than half way to DST on March 6, 2026.
@eg4eric does engineering think they will resolve this before then?
We all know that this was identified as an issue a year ago, and most recently on Nov-2 when it failed to exit DST.
Can you please offer a little reassurance that this is due for resolution in the coming firmware update?
Page 2 / 4
