GridBOSS and genera...
GridBOSS and generator
 eg4c
(@eg4c)
Are there any special steps I need to follow to enable generator in GrodBOSS? I see following error when clicking on ""
Also, perhaps someone knows what is the process for testing remote start? Manual says:
GridBOSS should use start/stop relay 1 in the normally open connection. Start/stop relay 1 can be
controlled by both manual control and by battery SOC/voltage logic within the EG4 ® Monitor Center.
The generator can also be configured with warm-up, cool-down, and exercise time.
Can somebody post a screenshot or perhaps tell me the steps, how do I manually control relay 1?
That seems to be the general error code for attempting to change any setting to a value that's out of range or not allowed. I would guess you have some other setting conflicting with what you are trying to do.
 eg4c
(@eg4c)
With the help from SignatureSolar, I received an answer: to control the remote start manually, grid power needs to be switched off. I turned off main breaker and the "
