My System keeps dis...
Question My System keeps disconnecting the generator when charging batteries
(@gblemire)
Hello,
I have a system with the following components
Gridboss21 + Flexboss21 + 3 Outdoor rated 280Ah batteries in parallel + Generac 18kW generator.
I lost grid power and i wanted to try to see if the generator would power the batteries. I set the SOC to 83% to start charging and 90% to stop charging using the generator. Once the batteries fell to 83%, the generator started and a few minutes later it is supplying power to the house and charging the batteries - all looks good. But a few minutes later the generator is disconnected but is still running and i go back to powering off of the batteries. A few minutes later the generator is connected and starts charging the batteries and the house, but is again disconnected after a few minutes.
So there are a few things I could think of that might cause this.
1) the generator power is noisy, but i don't see any faults or errors in the logs indicating this.
2) the load is too high for my generator. I set the Adc to 40 and i still see this issue, so i don't think this is the problem.
3) my system settings are somehow incorrect
4) my firmware is outdated. My Flexboss is FAB-2525, Gridboss is IAAB-1600 so i don't see any issues
5) my BMS is causing issues?
The good news is the generator does respond to Charge Start SOC and Charge END SOC, but the Generator is still disconnecting.
Best,
Guy
@gblemire
Do you know what percentage the batteries were at when the generator was cutting in and out?
(@belandbroc)
I have a 314ah wallmount battery that needs a firmware update to fix the 15amp charge limitation bug.  can you help?
(@jiggawatty)
My 12000XP would start to cycle the generator on and off when my generator had been  running for about 15 to 20 minutes- no matter the load requested for the charge , the max charge current limit , or the MAX SOC level set.  I actually returned the generator thinking it was defective, but it turned out it was simply a matter of updating the XP 12000’s firmware. It now charges steadily and happily with no fluctuations. I’m not sure if that’s the same issue you are  having, but it is very quick and easy to do an over the air firmware update. Good luck, because I know how frustrating this can be.
(@gblemire)
@jiggawatty thank you for your suggestion. Yes i am waiting for EG4 to let me know if my firmware is up to date. I suspect the battery firmware and the BMS (among other things) but i want to check my system setting first to see if i havce something setup incorrectly
(@gblemire)
hi Eric, the batteries were at 83%.
@gblemire
Does this happen occasionally or every time?
