12000xp - flickerin...
Question 12000xp - flickering on Battery with high-quality LEDs
(@galvan)
Hi there!
First full day on battery with after installing our 12000xp from Signature Solar and most / all of our lights are flickering at all dimming levels. We have over 60 of these lights, all Luton RadioRA2 dimmers + high end Lutron Certified lights/fixtures (CMF).
Is it possible we have been affected by the same hardware/firmware issue affecting other devices?
SNA12K-US Product
 EG3 PowerPro Lithium battery
12kW rating Firmware:
ceaa-0405
I don't believe this is a firmware issue. Significant flickering is typically related to wiring problems. I recommend checking that the neutral and ground wires are properly connected and secure, ensuring there are no loose connections.
LED lights are very sensitive to voltage especially on a dimmer switch. You may or may not have a wiring problem. My led lights do the same on dim. Put some regular light bulbs in and see if they flicker. If they do you definitely have a wiring problem probably a ground issue.
