TIme is wrong (DST)
TIme is wrong (DST)
9 Users
3 Reactions
(@decker)
I have this problem too. Hawaii time (-10) never had Daylight Savings yet when I uncheck the box it still turns it on later. Hopefully you get it fixed soon as my data is off by an hour.
@decker make sure to check the station time, end-user time, and the time on the settings are all the same. If they are not the same the time will invert back to how it was.
(@decker)
Thanks. All my times are the same but the desktop application is where it ask for Daylight saving time input. My work around is setting the time zone to -11 and will have to change it back to -10 when DST change happens. Maybe this should be defaulted to off!
(@darcymyers)
@jared I understand it takes time.  I just went back in tonight and daylight savings is set to YES yet again.  This has been the problem since February.  So just to be clear, every time I turn or set daylight savings to NO or OFF with in a few hours or less it resets back to YES throwing all of my schedules off by 1 hour.
@darcymyers our server engineers believe they have resolved the issue. Please let me know if this is still not corrected.
(@he-04)
(@mtmatt5150)
I have the same issue with the correct time not sticking with my GridBoss, firmware version IAAB-1300
(@he-04)
New Gridboss/Flexboss system.  Firmware IAAB-1300/FAAB-2021
DST does not stay off for more than 10-20 minutes, then reverts.
Page 2 / 3
