New System EG4 12 K...
New System EG4 12 Kw with battery EG4 314 AH in Venezuela
(@ajt_ccs)
Good afternoon. Just yesterday we Install and testing de eg 4 12 Kw in Venezuela. in 120/208 volts 60 hz
Everything work good, except the on grid. Normally in our country with use the inverter in back up Mode, Keping the battery full charger.
In these case. i can't find how to set up in Mode On Grid. Only i can keep charge the battery from the grid soc 90 to 90 %, but i want to keep full charge and use only isfd the grid faut.
Some sguestions about how to set on grid??
Regards
If you can share your inverter's serial number with me, I can help you with your system. También puedo asistirle en español.
