How to set max grid...
Question How to set max grid passthrough on 12000XP?
 ray
(@ray)
Where on the monitor center can we limit the max grid pass through amperage? I.E. I don't want to pull 100 amps on each of my inverters from the grid, ever. The only thing I see in the monitoring center has to with AC Charging which is limited to 30 amps, which seems fine. The instructions indicate we can adjust the passthrough from the 100 amps to something lower as well. But, as of yet I cannot find this setting.
Since the 12000XP is an off-grid inverter, the current input limit from the grid cannot be adjusted.
