Inverter Battery Se...
Inverter Battery Setting setup- 6000xp
(@cu5efan)
is anyone willing to show their battery setting setup?
I have an 6000xp inverter and 6x100ah batteries and a 3k solar array feed. (there is a gird tie as well)
I would like to set it up so the house runs off of the battery packs... solar recharges the battery packs and the grid would only kick in to charge the batteries if they hit 10% left and shut off the grid at 25%
The 6000XP is an off-grid inverter, designed to operate primarily using solar and battery. It will automatically utilize available solar power to charge the batteries and to power loads. If solar is insufficient, the system will draw additional power from the battery to meet load demand.
If you want to charge the batteries using the grid, you'll need to enable the AC Charge and configure the AC Charge Start to 10% and AC Charge End to 25%.
If you need further assistance with this, please let me know!
