314 Wallmount AutoI...
Question 314 Wallmount AutoID Master/Slave mismatch
(@carlrx7)
Hello,
I have two 314's in parallel.  The batteries "to me" are not displayed correctly on the web device monitoring page.  It is showing my slave battery as "battery 0" and the master as "battery 1".  Any way to fix this?
Battery 0 - Battery-ID-01 - V 3.21
Battery 1 - Battery-ID-02 - V 3.21
-Carl
@carlrx7
The monitoring website will display the Master battery as 0 and Battery #2 as Battery 01. This can be a little confusing, but it is normal behavior. Based on what you've described, your system appears to be showing the correct information.
(@carlrx7)
Posted by: @eg4eric
@carlrx7
master as 0 and slave as 1 would make sense.  However, mine does not display that.
Posted by: @carlrx7
