3 6000XPs in parall...
Question 3 6000XPs in parallel fans do not run at low wattage
Those temperatures are normal for the inverters. A high temperature warning will appear at 87°C, and a fault will trigger at 92°C. Since you're well below those limits, there's nothing to worry about. Your readings are within the normal range.
(@mikeenea)
@eg4eric Thank you Eric
I appreciate the information I will definitely sleep better now.
Best regards
Mike E.
