Flexboss setting to...
Flexboss setting to enable MID
(@texas-randy)
I am installing the Flexboss and Gridboss but hit a snag. There is no tab in the EG4 App or on the Monitor site to change the MID enable so the inverter will not start up the Gridboss during the configure procedure.
The manual states the following:
Select the “Maintenance” tab, and then expand “Application Setting”.
Click “Advanced Settings”, then select “Enable” next to the Midbox Enable setting.
The Midbox enable setting is not there.
Help needed !    Signature Solar Tech Support had no answers or resolution to this issue.
Could you please DM me the serial number for the FlexBOSS21 so I can take a look? Additionally, you should be able to use the local monitoring feature to enable the setting through the EG4 app.
(@texas-randy)
@jared You guys already got me up and running, Thanks !
